MPC5748g Flexray clock
1,353 次查看
WM
MPC5748g Flexray clock using PLL how to set
标记 (1)
1,319 次查看
davidtosenovjan
Yes, it is the configuration
1,343 次查看
davidtosenovjan
You may have two options:
- either 40MHz directly feeded by crystal oscillator
- or 80MHz clock feeded from PLL
I am recommending to use following clock configurator:
https://www.nxp.com/docs/en/application-note/AN5392.pdf
1,326 次查看
WM
Hello, davidtosenovjan
    Thank you for your answer.
     If FR_MCR[CLKSEL] is 1 in MPC5748, check whether other configurations are required in flexray PE clock?  I have configured FS80=80MHz.
1,320 次查看
davidtosenovjan
