MPC5748G serial port transfers lost bytes
lixu
I am using S32DS working on MPC5748G.
When I do serial communication, I always lose the second or third byte.
Has anyone encountered this situation, or how to solve this problem?
Thanks and best regards,
Li Xu
lukaszadrapa
do you have simple project to reproduce the problem? Which S32DS and which SDK version do you use?
Lukas
lixu
I'm using S32 Design Studio for Power Architecture Version 2.1.
And I've solved this problem. I lowered the baud rate and this problem won't occur.
best regards,
Lixu
