MPC5748G:how i can get flexray wakeup pattern?
1,230件の閲覧回数
helius0908
by used one board send wakeup pattern,i can see wakeup pattern in flexray bus
but,i can't get wakeup pattern in MPC5748G,
I had enable FR_WUPIF_IRQn,and set GIFER[WUPIE], however, IRQ don't trigger.
i also try other IRQ,such as FR_PRIF_IRQn, and i get trigger.
so, if i want get wakeup pattern, what i should set?
タグ(2)
2 返答(返信)
1,198件の閲覧回数
lukaszadrapa
can you see if the WUPIF flag is set?
Lukas
1,122件の閲覧回数
helius0908
hi
i had solved it.
i set a wrong data in wakeupsymbolRxIdle.
thanks
