MPC5748G Lwip error problem
656 次查看
yankuang1
When I tested the lwip routine, I found the following errors.However, this project can normally compile and generate elf files.Is there any way to avoid displaying this errorpastedImage_1.png
506 次查看
martin_kovar
it looks like false positive error from Eclipse parser. In case .elf file has been correctly created, you can ignore the error. There is one option you can try. Right click the project and try to reindex it.
Martin
