MPC5748 PB[0] and PB[1]
MichaelSun
Hi Support team,
I'm using MPC5748G REVD.  I want to use PB[0] and PB[1] as LIN0RX and LIN0TX. But i didn't find the pinout of these two pins.
Could you please help me check if there is any pinout of PB[0] and PB[1] ?
davidtosenovjan
Could you specify which evaluation board is this question related to? Thanks
MichaelSun
I found the following chip on the board.  So, i can just use TXD and RXD as the PB[0] and PB[1].
Am i right ?
