MPC5746R - e200z425n3 core spec
Search instead for
supra0309
I'm trying to figure out problems about XOSC_IRQHandler()&IVOR1_Exception_Handler when I execute my code in 5746R. I want to know if the spec of "e200z425n3 core" is public, please let me know how to fix it.
BR,
Xantia
davidtosenovjan
Core reference manuals are only describes core variants used on MPC55xx/56xx devices. Following documents exist comparing cores to each other:
https://www.nxp.com/docs/en/application-note/AN4802.pdf
https://www.nxp.com/webapp/Download?colCode=DWF14-AMF-AUT-T0345&location=null&fsrch=1&sr=3&pageNum=1...
Otherwise cores are only described in MPC57xx device reference manuals. For MPC5746RRM, specifically in chapter 7.
Full specification exists only as internal document and I can provide it to you if you have valid NDA.
If yes, please create a case (with reference to this thread) according procedure below and tell us you NDA number and I will provide the document to you:
https://community.nxp.com/t5/HomeTest-Knowledge-Base/How-to-submit-a-new-question-for-NXP-Support/ta...
supra0309
Is the third website public? It says I don't have sufficient privileges for this resource or its parent to perform this action, thanks.
BR,
Xantia
davidtosenovjan
These are our web sites, all 3 links are nxp sites. You need to be logged in.
supra0309
I've already logged in. But still don't have sufficient privileges for this resource or its parent to perform this action, thanks.
BR,
Xantia
davidtosenovjan
It seems the content is outdated anyway.
Here you may see video, it may be better:
https://www.nxp.com/video/tutorial-for-nxp-support-case-portal:NCP-VIDEO
Hope it helps
