MPC5746R Safety Manual SM_107 & SM_108
zhouxx
Hi:
   I will develop the MPC5746R safety-related application.
How to use CRC calculated PIT configuration.What is One FTTI in this description
petervlna
You SW will compare the CRC made under your PIT configuration (lets say offline)  with the actual one every one FTTI.
FTTI is Fault Tolerant Time Interval
regards,
Peter
zhouxx
Hi,Peter:
   thanks for your reply,which register is that need CRC calculate?PIT_MCR and PIT_LDVAL?
petervlna
You should monitor any register which is relevant for your counter functionality.
For example if you are using PIT0 then monitor its registers content.
regards,
Peter
