According to the safety manual, the CRC module are used for the register configuration check, for example the SIUL2 module.
SIUL2 module have a few hundreds MSCR register, but there are a lot of reserved gaps in the SIUL2 memory map.
As the pic shows, MSCR 65 to 79 are not included in the memory map. I tried to read some address between this range not covered by the memory map, the result is 0.
So here is my question, if I want to check the whole configuration about the SIUL2, can I read the address range cover MSCR0 to 255 and MSCR512 to 998, ignore the gaps in the memory map, or do I need to read the address ranges strictly by the memory gap? The former way is way easier that the latter, so I need a answer to guide my execution.
Thanks for your answer.
Solved! Go to Solution.
I expect you are referring to register content monitoring.
you have to skip reserved addresses reading.
Peter
Peter
Tks , peter
