MPC5744P S32DS and SPI
Search instead for
fangzanbin
Hi,all
I'm programming  MPC5744P by S32DS.There is a problem about SPI . I follow “MPC5447P.h” rule write the register.but It always remind me the addaress of CTAR register error. problem like this:
and then I see the register in SPI module like this:
Great thanks!
Fang Zanbin
martin_kovar
it seems you use S32 Design Studio version 1.0. I tested this use case in both version (1.0 and 1.1) and in the newer version it works correct. Please download S32 Design Studio version 1.1 and install update 1.
http://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=S32-DS-E200
S32 Design Studio for Power v1.1 - Update 1 available
Please let me know, if my consideration was correct and if it works with S32DS v1.1.
Martin
martin_kovar
Martin
fangzanbin
Dear Kovar
Thank you for your guide,I tried to follow your link,but the web is outage.,I update  the software from inside of the software to S32 Design Studio for Power v1.1 - Update 1 ,and the problem is resolved.
Thank you again!
Fang Zanbin
