MPC5744 freeRtos demo problem
282707061
Hi NXP Team:
I had a problem debugging freertos;
I use your demo project " freertos_mpc5744p",and debug it;Your IDE (S32 DS) console window print the following  error :
then I found out,the error is caused by the  function :
g_clockState.callbackConfig[callbackIdx];
I don't know if I need to configure anything, (eg:using clockMan, etc.)
Can any one help me to solve this problem, thank you.
Best wishes!
lukaszadrapa
the only advice here is to check the clock settings. Do you have the same crystal frequency as configured in the project?
Lukas
