MPC5744 etimer capture fail in one channal
1,384件の閲覧回数
pingli
Hi,NXP
look the file ,6 Measure signal parameters:
void eTimer_Init(uint8_t EtimerN,uint8_t DspiNumber)
volatile struct ETIMER_tag *pETIMERn;
switch(EtimerN)
{ //choose base eTimer address
case 0 : pETIMERn = &ETIMER_0; break;
case 1 : pETIMERn = &ETIMER_1; break;
case 2 : pETIMERn = &ETIMER_2; break;
default: pETIMERn = &ETIMER_0; break;
pETIMERn->ENBL.R = 0x0; // disable Timer0 channels
/* Configure the channel */
// pETIMERn->CH[DspiNumber].CTRL1.R = 0x38C1;//0x2001;//0x3801; // Counts only rising edge of the MC_CLK (100MHz in RUN0), divide by 1, count up, count repeatedly, rollover
pETIMERn->CH[DspiNumber].CTRL1.B.PRISRC = 0x18;
pETIMERn->CH[DspiNumber].CCCTRL.B.CPT1MODE = 2;
pETIMERn->CH[DspiNumber].CCCTRL.B.CPT2MODE = 1;
pETIMERn->CH[DspiNumber].CTRL1.B.LENGTH = 0;
pETIMERn->CH[DspiNumber].CTRL1.B.ONCE = 0;
pETIMERn->CH[DspiNumber].CTRL1.B.SECSRC = DspiNumber;
pETIMERn->CH[DspiNumber].CTRL1.B.CNTMODE = 1;
pETIMERn->CH[DspiNumber].COMP1.R = 0xFFFF;
pETIMERn->CH[DspiNumber].CCCTRL.R = 0x0264; // compare on COMP1 when counting up, COMP2 when counting down
// CAPT2 on falling edge, CAPT1 on rising edge, 2 entries
// free-running mode
pETIMERn->CH[DspiNumber].CCCTRL.B.ONESHOT = 1;
pETIMERn->CH[DspiNumber].CCCTRL.B.CFWM = 2;
pETIMERn->CH[DspiNumber].CTRL3.R = 1;
pETIMERn->CH[DspiNumber].CTRL3.B.ROC = 3;
pETIMERn->ENBL.B.ENBL |= (1<<DspiNumber); // Enable Timer0 channel 1
pETIMERn->CH[DspiNumber].CCCTRL.B.ARM = 1; // starts the input capture process
//pETIMERn->CH[DspiNumber].CCCTRL.B.ONESHOT = 1;
void eTimer_EnableChannal(uint8_t eTimerN,uint8_t DspiNumber)
switch(eTimerN)
void eTimer_Value(uint8_t EtimerN,uint8_t DspiNumber)
uint32_t counts;
uint32_t capture_ch[4];
uint8_t eTimerSTS = 0;
float freq,period,duty,pulseH,pulseL;
eTimer_Channal.duty = 0;
eTimer_Channal.Freq = 0;
eTimer_Channal.Period = 0;
switch(EtimerN)
while((pETIMERn->CH[DspiNumber].STS.B.ICF1 == 0x0)||(pETIMERn->CH[DspiNumber].STS.B.ICF2 == 0x0))
{ //(pETIMERn->CH[DspiNumber].STS.B.ICF1 == 0x0)||(pETIMERn->CH[DspiNumber].STS.B.ICF2 == 0x0)
// Delayms(100);
// if(!(0x0080 & pETIMERn->CH[DspiNumber].STS.R)) eTimerSTS = 1;
pETIMERn->CH[DspiNumber].CCCTRL.B.ARM = 0; // stop the input capture process
pETIMERn->CH[DspiNumber].STS.B.ICF1 = 0x1;
pETIMERn->CH[DspiNumber].STS.B.ICF2 = 0x1;
capture_ch[0] = pETIMERn->CH[DspiNumber].CAPT1.R; //First rising edge
capture_ch[1] = pETIMERn->CH[DspiNumber].CAPT2.R; //First falling edge
capture_ch[2] = pETIMERn->CH[DspiNumber].CAPT1.R; //Second rising edge
capture_ch[3] = pETIMERn->CH[DspiNumber].CAPT2.R; //Second falling edge
counts = capture_ch[2] - capture_ch[0];
eTimer_Channal.Freq = (float)(100000000.0/counts);
eTimer_Channal.Period = (counts / (float)100000.0)*1000000;
counts = capture_ch[1] - capture_ch[0];
pulseH = (counts /100000.0)*1000000;
// eTimer_Channal.duty = pulseH/period*100;
eTimer_Channal.duty = ((uint16_t)((capture_ch[1] - capture_ch[0])*1000)/(uint16_t)(capture_ch[2] - capture_ch[0]));
PWM:25Hz
why I get the  duty fail
clipping
5 返答(返信)
926件の閲覧回数
pingli
Hi,Pert
Thank you very much!
In the Example-MPC5744P-eTimer-frequency_measurement-v1_0-GHS614,
channal 0 input,why I   need konw" while(!(0x0080 & ETIMER_0.CH[1].STS.R))"
while(!(0x0080 & ETIMER_0.CH[1].STS.R)){} // wait for channel 1's capture2 flag
while(!(0x0080 & ETIMER_0.CH[0].STS.R)){}
926件の閲覧回数
pingli
Hi,Petr
switch(EtimerN)
// pETIMERn->CH[DspiNumber].CTRL1.R = 0x3804; // Counts only rising edge of the MC_CLK (100MHz in RUN0), divide by 1, count up, count repeatedly, rollover
pETIMERn->CH[DspiNumber].CTRL1.B.PRISRC = 0x1F;
// pETIMERn->CH[DspiNumber+1].CTRL1.R = 0xF004; // Counts only rising edge of the MC_CLK (100MHz in RUN0), divide by 1, count up, count repeatedly, rollover
pETIMERn->CH[DspiNumber].CTRL1.B.CNTMODE = 3;
pETIMERn->CH[DspiNumber].CTRL1.B.PRISRC = 0x10+DspiNumber;
pETIMERn->CH[DspiNumber+1].COMP1.R = 0xFFFF;
pETIMERn->CH[DspiNumber+1].CCCTRL.R = 0x0264;
pETIMERn->CH[DspiNumber+1].CTRL3.R = 1;
pETIMERn->CH[DspiNumber].CTRL1.B.CNTMODE = 1;*/
// pETIMERn->CH[DspiNumber].COMP1.R = 0xFFFF;
// pETIMERn->CH[DspiNumber].CCCTRL.R = 0x0264; // compare on COMP1 when counting up, COMP2 when counting down
// pETIMERn->CH[DspiNumber].CCCTRL.B.ONESHOT = 1;
// pETIMERn->CH[DspiNumber].CTRL3.R = 1;
// pETIMERn->CH[DspiNumber].CTRL3.B.ROC = 3;
pETIMERn->ENBL.B.ENBL |= (1<<DspiNumber)||(1<<(DspiNumber+1)); // Enable Timer0 channel 1
// pETIMERn->CH[DspiNumber].CCCTRL.B.ARM = 1; // starts the input capture process
switch(eTimerN)
double counts[2];
uint32_t capture_ch[4],capture_ch1[4],edge[5];
double freq,period,duty,pulseH,pulseL;
switch(EtimerN)
pETIMERn->CH[DspiNumber+1].CCCTRL.B.ARM = 1;
while(!(0x0080 & pETIMERn->CH[DspiNumber].STS.R))
// Delayms(100);
while(!(0x0080 & pETIMERn->CH[DspiNumber+1].STS.R))
// Delayms(100);
// pETIMERn->CH[DspiNumber].CCCTRL.B.ARM = 0; // stop the input capture process
// pETIMERn->CH[DspiNumber].STS.B.ICF1 = 0x1;
// pETIMERn->CH[DspiNumber].STS.B.ICF2 = 0x1;
capture_ch1[0] = pETIMERn->CH[DspiNumber+1].CAPT1.R; //First rising edge
capture_ch1[1] = pETIMERn->CH[DspiNumber+1].CAPT2.R; //First falling edge
capture_ch1[2] = pETIMERn->CH[DspiNumber+1].CAPT1.R; //Second rising edge
capture_ch1[3] = pETIMERn->CH[DspiNumber+1].CAPT2.R; //Second falling edge
edge[1] = capture_ch1[0]*65536 + capture_ch[0]; // save 1st rising edge
edge[2] = capture_ch1[1]*65536 + capture_ch[1]; // save 1st falling edge
edge[3] = capture_ch1[2]*65536 + capture_ch[2]; // save 2nd rising edge
edge[4] = capture_ch1[3]*65536 + capture_ch[3]; // save 2nd falling edge
if(edge[3]>edge[1])
counts[0] = edge[3] - edge[1];
else
counts[0] = (0xFFFFFFFF - edge[1] +1) + edge[3];
eTimer_Channal.Freq = (float)100000000.0/counts[0];
eTimer_Channal.Period = counts[0] / (float)100000.0;
if(edge[2]>edge[1])
counts[1] = edge[2] - edge[1];
else
counts[1] = (0xFFFFFFFF - edge[1] +1) + edge[2];
pulseH = counts[1] / (float)100000.0;
pulseL = eTimer_Channal.Period-pulseH;
eTimer_Channal.duty = counts[1]*100/counts[0];//pulseH/eTimer_Channal.Period *100;
pETIMERn->CH[DspiNumber].STS.R = 0x00C0; // clear eTimern channel n's capture1/2 flags
pETIMERn->CH[DspiNumber+1].STS.R = 0x00C0; // clear eTimern channel n's capture1/2 flags
I get duty fail.
eTimer1 ,channal4;
Clipping
926件の閲覧回数
PetrS
you have wrong setting for cascaded channel, it should be
pETIMERn->CH[DspiNumber+1].CTRL1.B.CNTMODE = 7;
pETIMERn->CH[DspiNumber+1].CTRL1.B.PRISRC = 0x10+DspiNumber;
pETIMERn->CH[DspiNumber+1].CTRL1.B.SECSRC = DspiNumber;
Also as you are using prescaler=128, you need to add this into relevant calculations.
BR, Petr
926件の閲覧回数
PetrS
If the channel is counting MC_CLK/1 (100MHz) and you measure 25Hz PWM signal, then expected counts per period will be 100e6 / 25 = 4 000 000 counts. The eTimer has just 16bit counter, thus for low frequency input signal you have to handle counter overflows or use slower internal counting clock (this way you will lose the precision).
Another possibility could be usage of cascaded counters, which serves overflow counting in HW.
The example using cascaded counters is here: https://community.nxp.com/docs/DOC-104285
BR, Petr
926件の閲覧回数
pingli
   Hi, Petr
Thank You!
switch(EtimerN)
switch(eTimerN)
double counts[2];
switch(EtimerN)
// Delayms(100);
// Delayms(100);
if(edge[3]>edge[1])
else
if(edge[2]>edge[1])
else
I fail to get duty. (eTimer1,channal4);
Clipping
