MPC5741P调试问题
MPC5741P调试问题
838927242
用lauterbach调试MPC5741P,插上调试前不启动调试单片机状态正常,启动调试后,单片机无法正确反馈PIN脚寄存器的状态,具体如下:
PF10配置为输入,监测外部开关量信号,实际测试单片机引脚为高,但是启动调试后,读取寄存器的值,为0;
PF11配置为输出,启动调试后不能正常输出控制电位;
其他输入口正常!
838927242
838927242
Hi!
Thanks for your help !!!
I've fixed this issue!
https://community.nxp.com/t5/MPC5xxx/how-to-disable-Nexus-Function/m-p/1087521
lukaszadrapa
these pins are EVTO and EVTI which can be used by debugger:
 You can find in this manual: c:\T32\pdf\debugger_mpc5500.pdf
If you want to use the pins as GPIO, turn this option off.
Lukas
