MPC5644a read/write flexcan registers error
1,181件の閲覧回数
haowu
Hello, Guys. i am working on MPC 5644A flexcan module.  Any read/write to flexcan registers makes my program jump to below portion of  ivor_branch_table() and stuck there forever. Any suggestion where do i go wrong is highly appreciated!
asm void ivor_branch_table()
IVOR1trap: b IVOR1trap // Machine check / (NMI) interrupt handler
                                       // ISI, ITLB Error on first instruction fetch for an exception handler
                                       // Parity Error signaled on cache access
                                        // External bus error
1,092件の閲覧回数
davidtosenovjan
Hi, at first it is needed to investigate MCSR register to find out machine check reason.
