MPC5554 loss of clock testing
641 次查看
ganeshsullad
I am planning to use the feature provided in MPC5554 Loss of Clock interrupt in case of clock loss. However, I did not get from the datasheet the method to test this feature.
Please let me know if anybody know how to create the scenario for loss of clock which in turn generate interrupt?
Ganesh
550 次查看
ganeshsullad
Ok, Thank you David Tosenovjan. I will try this method.
Ganesh
550 次查看
davidtosenovjan
Hi, you could connect EXTAL pin to ground for a while to initiate loss-of-clock. I guess on this device this cannot be initiated SW way.
Loss-of-lock condition should be possible to inject by changing of PLL frequency software way.
