hi ,
I have a MPC5775E evaluation board with me. Needs an example project in S32 Design studio to make it working on the evaluation board. I cant find any example project with respect to MPC5775E. Needs some guidance here.
Krishna
MPC5775B/E devices are compatible with MPC5777C, so you can choose any example code unless it uses modules that are not present on MPC5775B/E.
If you have, MPC5775E-EVB, here you can see getting started document:
https://www.nxp.com/docs/en/application-note/AN12875.pdf
Thanks for the reply. LED is not blinking when I used example code hello world of MPC5777C micro.Please let me know what am i doing wrong.
its ok LED is blinking.
