I am a newbie on NXP boards. I should be designing an AVAS system as mentioned on subject. I put a file that describes AVAS. Basically if your EV travels with less than 20 kmh, then a combustion engine sound is generated, this is what AVAS does. I have an amplifier, FDA903D, and a speaker with MCP 5748G. I am unable to proceed because learning the NXP is challenging. I should send data through dspi or i2c. How should I proceed, how can I make things easier? Indeed, this is an easy task, but when you are familiar with the board you use.
Thanks.
解決済! 解決策の投稿を見る。
Hi @black_light
Each board has user manual in pdf or Getting Started html document.
For example, if you have this board:
https://www.nxp.com/design/design-center/development-boards-and-designs/automotive-development-platf...
... you can find on the page:
https://www.nxp.com/document/guide/getting-started-with-the-devkit-mpc5748g:NGS-DEVKIT-MPC5748G
Then there's a nice training describing how to install S32DS and SDK and basic steps:
https://www.nxp.com/design/training/sdk-for-the-gateway-mpc574xb-c-g-mcu-family:VIDEO-MPC574xBCG-MCU
SDK then contains set of examples which you can use for first tests and learning.
Lukas
Thanks a lot. I hope these will be helpful.
BlackLight
Hi @black_light
Lukas
