The error will be detected when IO_4=0 for >20us and IO_5=1 (no acknowledgement). In that case, FS0B is asserted low after 9.7ms (T_ACK_FS). To enable this, the IO_45_FS bit in the INIT_FSSM1 needs to be set to 1 ( = safety critical).
Please let me know if there are any other questions.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
Tomas
