Has anyone gotten MBEDTLS to work on the MPC5748G?
I have tried to get the HSM module and not able to. I have been getting the run around with no one wanting to giving me access to this software so I gave up and I am trying a different path. I have tried to get wolfSSL work with no success. Is there a TLS library I can add that does not require using the HSM module or a way around having to use the HSM module on wolfssl because I do not think anyone is going to give me the HSM module.
Hmm, there is no FW you can get standalone. Either you order sample with FW from factory or you write your own HSM FW.
I am not sure about the ordering of secure sample, but you need to contact local vendor or NXP ask ask specifically for it.
I do not see any issue to get hand on them, as those are not new devices and there is already HSE-B module on new ones.
Have you sign NDA with NXP?
Peter
Never heard of anyone trying to use it in all those years.
Everyone is simply using HSM module and its FW for cryptographic services.
Peter
