Linker file data editing and auto generation in s32ds v2.1 ide with mpc5744p
AndrewwDabach
I am working with MPC5744P with the e200z4 processors. I am using the S32DS IDE version 2.1 with the integrated NXP gcc comiler v4.9. When I created an example project, the linker file was auto generated under the folder "Project_Settings -> Linker_Files ->..."
To make changes to the linker file data, can I modify it in some GUI options (processor expert,...) and re-generate it or is it only possible to modify it directly on the generated linker file ?
Thank you
MPC574xP DEVKIT-MPC5744P S32DS-PA
PetrS
there is no option in the PE, you should modify generated linker file directly.
BR, Petr
PetrS
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-2080793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinker%20file%20data%20editing%20and%20auto%20generation%20in%20s32ds%20v2.1%20ide%20with%20mpc5744p%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2080793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20working%20with%20MPC5744P%20with%20the%20e200z4%20processors.%20I%20am%20using%20the%20S32DS%20IDE%20version%202.1%20with%20the%20integrated%20NXP%20gcc%20comiler%20v4.9.%20When%20I%20created%20an%20example%20project%2C%20the%20linker%20file%20was%20auto%20generated%20under%20the%20folder%20%22Project_Settings%20-%26gt%3B%20Linker_Files%20-%26gt%3B...%22%3C%2FP%3E%3CP%3ETo%20make%20changes%20to%20the%20linker%20file%20data%2C%20can%20I%20modify%20it%20in%20some%20GUI%20options%20(processor%20expert%2C...)%20and%20re-generate%20it%20or%20is%20it%20only%20possible%20to%20modify%20it%20directly%20on%20the%20generated%20linker%20file%20%3F%3C%2FP%3E%3CP%3EThank%20you%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FMPC574xP%2Fpd-p%2FMPC574xP%22%20class%3D%22lia-product-mention%22%20data-product%3D%221076-1%22%20target%3D%22_blank%22%3EMPC574xP%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FDEVKIT-MPC5744P%2Fpd-p%2FDEVKIT-MPC5744P%22%20class%3D%22lia-product-mention%22%20data-product%3D%223213-1%22%20target%3D%22_blank%22%3EDEVKIT-MPC5744P%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32DS-PA%2Fpd-p%2FS32DS-PA%22%20class%3D%22lia-product-mention%22%20data-product%3D%223478-1%22%20target%3D%22_blank%22%3ES32DS-PA%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2080885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linker%20file%20data%20editing%20and%20auto%20generation%20in%20s32ds%20v2.1%20ide%20with%20mpc5744p%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2080885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Ethere%20is%20no%20option%20in%20the%20PE%2C%20you%20should%20modify%20generated%20linker%20file%20directly.%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
