How to read pwm signals in MPC5777C microcontroller? Is there any application example, or code example?
Solved! Go to Solution.
The example can be used this one as starting point:
or you can use SPC5748G example from S32DS, the mode module is the same:
Peter
Peter
Yes, it is possible.
For such purpose this chip offer:
1. eMIOS where you can use input capture mode (reference manaul :36.6.1 Unified Channel (UC))
2. eTPU whole signal processing unit
Peter
