Interrupt driver for MPC504B compile with Green Hills
yyang
I use MPC5604B on Green Hills - Multi and I search an interrupt driver example for MPC5604B .
I have found an example for MPC5744P build with GHS6.1.4 .  But I don't know where to find this file which I need to create a project in GHS. Such as, the linker file、startup file ....
Otherwise are there examples on MPC5604B based on Green Hills ?
Thanks & Regards
Y.YANG
davidtosenovjan
Hi, our example list you may find here:
MPC5 software example list
We have made our examples for MPC55xx/MPC56xx mostly with CodeWarrior 2.10 or CodeWarrior 10.6, and examples for MPC57xx usually with GHS6.1.4 or S32 Design Studio.
Other configurations you will have to port yourself, I believe GHS has some templates for MPC56xx as well.
yyang
Could I port a MPC56xx S32 Design Studio project to GHS ?
I found that "Example-MPC5646C-PIT-ISR-v1_0-GHS614.ZIP" , in  MPC5 software example list .  Could I use this templates to create a MPC5604 project?
