I cannot find out MAC57D54 PLL power supply in datasheet and RM , would you please supply reference document?
Search instead for
jacky_Tan
MAC57D54_clock.pngwhich power pin is provioded power supply for this clock sysytem?
martin_kovar
Hello Jacky,
please check the table below:
Martin
jacky_Tan
Hi Martin,
Thanks you answer my question.
Desay need know which pins supply SAC57D53HCVMO(516 MAPBGA package)PLL Power and Ground pin.
Would you help me point out the power supply pins for PLL power and Ground as below ?
516BGA Ballmap
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
PK[7]
PK[4]
PK[1]
PJ[15]
PJ[13]
PJ[11]
PJ[10]
PJ[8]
PJ[6]
PJ[5]
PJ[3]
PJ[1]
PJ[0]
DDR_DQ21
DDR_DQ16
DDR_DQS2
DDR_DQ20
DDR_DQ17
DDR_DQM2
VDDE_A
PH[8]
PH[3]
VDDE_A
PM[12]
PK[9]
VSS
PK[5]
PK[2]
VSS
PJ[14]
PJ[12]
VSS
PJ[9]
PJ[7]
VSS
PJ[4]
PJ[2]
VSS
DDR_DQ18
DDR_DQ23
VSS
DDR_DQ19
DDR_DQ22
VSS
PH[9]
PH[5]
VSS
PR[0]
VSS
VDDE_A
PK[10]
PK[8]
PK[6]
PK[3]
PK[0]
DDR_A10
DDR_BA2
DDR_CKE
DDR_CLK
DDR_A5
DDR_A15
DDR_A13
DDR_A6
DDR_CAS
DDR_RAS
DDR_DQ26
DDR_DQ31
DDR_DQ28
DDR_DQ25
DDR_DQM3
PH[7]
PH[6]
PH[2]
PM[11]
PR[1]
PM[10]
DDR_DQM0
DDR_A14
DDR_A12
DDR_A9
DDR_A7
DDR_A1
DDR_BA0
DDR_WE
DDR_CLKB
DDR_A2
DDR_A11
DDR_A8
DDR_A4
DDR_CS
DDR_DQ29
DDR_DQ24
DDR_DQS3
DDR_DQ27
DDR_DQ30
PH[10]
PH[4]
PH[1]
PG[13]
PG[12]
PG[11]
PS[2]
DDR_DQ4
VSS
DDR_DQ12
DDR_DQM1
VSS
DDR_A3
VDDE_SDR
VSS
DDR_BA1
VDDE_SDR
VSS
VDDE_SDR
DDR_A0
VSS
DDR_ODT
VSS
VDDE_SDR
PH[12]
VSS
PH[11]
PH[0]
VSS
PS[1]
PG[10]
VSS
VDDE_A
DDR_DQ1
DDR_DQ3
DDR_DQ9
DDR_DQ11
VDDE_SDR
VDDE_DDR
VDDE_DDR
VDDE_DDR
DDR_VREF
VDDE_DDR
VDDE_DDR
VDDE_DDR
VDDE_DDR
VDDE_A
VDDE_A
PS[0]
PG[9]
PS[3]
PG[7]
PS[4]
DDR_DQS0
DDR_DQ6
DDR_DQS1
DDR_DQ14
VDDE_DDR
PG[8]
PS[5]
PG[6]
PG[5]
PS[6]
DDR_DQ2
VSS
DDR_DQ8
DDR_DQ10
VSS
VDDE_DDR
VDDE_A
VSS
PG[3]
PG[4]
VSS
VDDE_A
DDR_DQ7
DDR_DQ0
DDR_DQ13
DDR_DQ15
VDDE_DDR
PG[2]
PG[1]
PG[0]
PS[7]
PS[13]
DDR_DQ5
PK[13]
PK[12]
PK[11]
VDDE_SDR
VDDE_DDR
VSS
VSS
VDD_LV
VSS
VSS
VDD_LV
VSS
VSS
PS[12]
PS[11]
PS[10]
PS[9]
PS[8]
PR[9]
PL[0]
VSS
PK[15]
PK[14]
VSS
VDDE_DDR
VSS
VDD_LV
VSS
VDD_LV
VDD_LV
VSS
VDD_LV
VSS
VDDE_A
VSS
PR[8]
PR[7]
VSS
VDDE_A
PL[4]
PL[3]
PL[2]
PL[1]
VDDE_SDR
VDD_LV
VSS
VSS
VSS
VSS
VSS
VSS
VDD_LV
PR[6]
PR[5]
PR[4]
PR[3]
PR[2]
PL[7]
PL[8]
PL[9]
PQ[0]
PL[5]
PL[6]
VSS
VDD_LV
VSS
VSS
VSS
VSS
VDD_LV
VSS
PM[13]
PM[14]
JTAG_TCK
TRACE13
TRACE14
TRACE15
VDDE_B
VSS
PL[10]
PQ[1]
VSS
VDDE_B
VSS
VDD_LV
VSS
VSS
VSS
VSS
VDD_LV
VSS
VDDE_A
VSS
TRACE12
JTAG_TMS
VSS
VDDE_A
PL[11]
PQ[2]
PL[12]
PQ[3]
PL[13]
VDD_LV
VSS
VSS
VSS
VSS
VSS
VSS
VDD_LV
TRACECLK
TRACE8
TRACE9
TRACE10
TRACE11
PQ[4]
PQ[5]
PL[14]
PQ[6]
PQ[7]
PQ[8]
VSS
VDD_LV
VSS
VDD_LV
VDD_LV
VSS
VDD_LV
VSS
VDDE_A
TRACE4
TRACE5
TRACE6
TRACE7
VPP_TEST
VDDE_B
VSS
PQ[9]
PQ[10]
VSS
VDDE_B
VSS
VSS
VDD_LV
VSS
VSS
VDD_LV
VSS
VSS
VDDE_A
VSS
RESET
EXTAL
VSS
XTAL
PQ[11]
PQ[12]
PQ[13]
PA[0]
PA[2]
VDD_LP_DEC
VRC_CTRL
PORST
EXTAL32
XTAL32
PQ[14]
PA[1]
PA[3]
PA[4]
PP[10]
VDDE_B
VSS
TRACE3
TRACE2
TRACE1
VSS
TRACE0
PP[11]
VSS
PA[5]
PA[6]
VSS
VDDEH_ADC
PF[0]
PF[1]
PF[2]
TRACECTL
VDDE_B
PP[12]
PP[13]
PP[8]
VDDE_B
VDDE_B
VDDE_B
PN[13]
PN[15]
PM[4]
PM[9]
PC[15]
PC[14]
VDDM_SMD
VSSEH_ADC
PE[11]
PE[12]
PE[13]
PE[14]
PE[15]
PA[7]
PA[8]
PN[0]
PN[1]
VSS
VDDE_B
PN[7]
VSS
VDDE_B
PN[14]
VSS
PP[3]
PM[5]
VSS
OLDI_P1
OLDI_N1
VSS
VDDM_SMD
PC[5]
VSS
PD[7]
PF[3]
PE[9]
VDDA
VSSA
PE[10]
VSS
VSS
PN[2]
PN[3]
PB[1]
PB[3]
PB[5]
VSS
PN[11]
PB[9]
PP[0]
PP[5]
PM[3]
PM[8]
OLDI_N0
OLDI_P2
PC[12]
PC[11]
PC[4]
PC[2]
PD[6]
PD[1]
PF[4]
PE[7]
PE[5]
PE[8]
PA[9]
PA[10]
PA[11]
PA[12]
PB[2]
PB[4]
PB[6]
PN[10]
PN[12]
PB[10]
PP[2]
PP[4]
PM[2]
PM[7]
OLDI_P0
OLDI_N2
PC[13]
PC[10]
PC[7]
PC[3]
PD[4]
PD[0]
PF[5]
PE[3]
VDDA_REF
PE[4]
VDDE_B
VSS
PA[13]
PA[14]
VSS
PN[5]
PN[8]
VSS
PB[7]
PB[11]
VSS
PP[6]
PM[1]
VSS
OLDI_CLKN
OLDI_P3
VSS
PC[9]
PC[6]
VSS
PD[5]
PD[3]
PF[6]
PE[2]
VSSA_REF
PE[6]
PA[15]
PB[0]
PN[4]
VDDE_B
PN[6]
PN[9]
VDDE_B
PB[8]
PB[12]
PP[1]
PP[7]
PM[0]
PM[6]
OLDI_CLKP
OLDI_N3
VDDE_B
PC[8]
PC[1]
PC[0]
VDDM_SMD
PD[2]
PF[7]
PE[0]
PE[1]
Jacky
martin_kovar
please see the figure below. It shows, which pins supply which power domain.
These pins above are the ones. All these pins must be connected and it is not possible to tell, which pins supply which module. It works like one complex thing.
Hope it helps.
Martin
