How to turn off internal CAN for FS6500
283230333
The FS6500 we chose contains LIN, so it does not contain FS1B.As I saw in the manual, the INIT_FAULT register in the FS6500 can be set after the FS1B is asserted and the CAN transceiver is not transmittable. But I don't have FS1B in the FS6500, so I would like to ask how to close the internal CAN in fail-safe in this case?
Tags (2)
petervlna
I am not able to understand what do you mean by this question, could you please explain it more closely?
regards,
Peter
283230333
I want to disable the CANBUS receive and transmit .Just like the standby mode of TJA1044 , we can disable the receive and transmit by the STB pin on the TJA1044.
petervlna
Hmm,
There is no CAN on this part, how you want to disable it or put it into standby mode?
I am still not sure if I understood your question.
regards,
Peter
