How to rewrite MPC5744p  utest area
Search instead for
xiaobozheng
Dear all :
        now , our project need to bypass startup self-test,   According to the mpc5744p datesheet:
To configure "No self-test execution": Store the following DCF record as the first record
in the UTEST flash memory.
00000400h
00080000h
    But we found Standard Software Driver v1.1.0 , there is no example to show how to rewrite  UTest flash area, please tell us how to bypass startup selftest or reprogram Utest area ?
petervlna
I recommend you to read application note which deals with this thematic:
MPC5744P Startup STCU Overview
I have also attached for you the script for Lauterbach debugger disabling BISTs.
Peter
xiaobozheng
this document is Lauterbach debug tools script.   but we use winidea debug tools and Multi compiler. so can you creat one simple sw example for us ? thanks very much!
