How to program Utest DCF to my MPC5748G
sunhuajun
Hello every one,
    I have a question that:I know that I can update DCF by PE,I just want to know can I update the dcf record in doing s19 update by use CAN UDS Service?
petervlna
Yes you can program DCF via s record files. This is the only way PE can do it as far as I know.
Have a look at our DCF calculator where also s recod files for PE is generated.
Programming UTEST flash (where DCF sits) is no different then programing any other flash block. The procedure is same.
See AN for more details:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/MPC57xx-DCF-records/ta-p/1114884
and guide for PE:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Program-DCF-record-into-UTEST-fl...
Peter
