How to flash sample programs on MPC5777C EVB
969件の閲覧回数
shankarig
How to flash sample programs on MPC5777C EVB? Are there any flash tools available? Any emulators used along with IDE? If yes, any document available to flash the code into target??
814件の閲覧回数
martin_kovar
it depends on the IDE you use.
If you have GHS IDE, you can use Green Hills probe Multi-core JTAG, EJTAG, COP, BDM hardware assisted debugger, embeddeddebugging, on-chip debugging - ...
If you have S32 Design Studio, you can use Universal Multilink Development Interface Universal Multilink Development Interface|NXP
Third possibility is to use Lauterbach, which can be used with both IDEs mentioned above and also with some other IDEs and compilers.TRACE32® Qorivva MPC5xxx and SPC5xxx Debugger
Martin
