How to flash a elf file from Davinci to MPC5748G evaluation board by S32DS
zengqi300
I have a  PE debugger and MPC5748G evaluation board  and got a elf file about autosar from  Davinci Configuration tool .
I want to debug my elf file on MPC5748G platform but  I don't know using S32DS to debug without building relevant project is possible or not.
If it is possible ,how to implement?  if not  what  means can I use?
Can you help me? Thank you.
davidtosenovjan
Hi, here there is a described a procedure how to do it:
https://community.nxp.com/docs/DOC-332252
zengqi300
Hi:
 I  have followed the first method,but  console indicate
"MPC574xG Device detected.
No breakpoints currently set.
Disconnected from "127.0.0.1" via 127.0.0.1
Target Disconnected.
Target Disconnected."
Is it successe or not?
davidtosenovjan
Have your code been downloaded to the MCU?
