How to configure SAR ADC
2,952 次查看
俊翔兰
HI,ALL
I want to use SAR ADC to detect the PWM, how should I configure the ADC.Do you have example?
7 回复数
2,360 次查看
PetrS
you can find several ADC examples here MPC5 software example list
If you need to synchronize ADC sampling with PWM you can refer to https://community.nxp.com/docs/DOC-102559
BR, Petr
2,359 次查看
俊翔兰
      How to determine the sampling frequency of SARADC?
2,360 次查看
PetrS
could you specify the MCU you have?
BR, Petr
2,359 次查看
俊翔兰
MPC5775K
2,360 次查看
PetrS
read chapter 40.5.11 "Conversion Time" of the device RM; https://www.nxp.com/docs/en/reference-manual/MPC5775KRM.pdf
BR, Petr
2,360 次查看
俊翔兰
Thank you very much,but I have a question,What is the difference between ADC_CTR0 and ADC_CTR1?
2,360 次查看
yinlei
Break zero reply
