How can I know where the machine check exception is triggered, and solve it
zyz
Occasionally I encounter machine check exceptions, causing the program to get stuck in IVOR1_Handler, which makes me very confused. I don't know where it caused it. I want to know how to analyze the machine check exception and where to trigger the machine check exception.
davidtosenovjan
HI, could you specify used device? Thanks
zyz
I am using MPC5748G,thanks
