Get the microcontroller clock frequency
2,022 次查看
曾经怀念
Hi all,
      How can I Getting the microcontroller clock frequency. So, I could use to change the CAN or LIN baud
标记 (1)
1,657 次查看
lukaszadrapa
which device do you use?
Lukas
1,657 次查看
曾经怀念
Hi Lukas,
     MPC5606B
1,657 次查看
lukaszadrapa
By default, the device is running at system clock frequency given by internal RC oscillator 16MHz. Then it's a matter of your software. Take a look at this example to see how to initialize mode and clocks:
https://community.nxp.com/docs/DOC-329441
Here you can find PLL calculator which can help you to do own configuration:
https://community.nxp.com/docs/DOC-332694
If you want to confirm the system clock frequency by measurement, use CLKOUT pin (must be configured by SW, see reference manual for more details).
Lukas
