External memory access malfunction when mpc5777c ebi bus clock set
Woo
When the ebi bus clock of mpc5777c is set to 50mhz(300hz core clock) or 66mhz(264mhz core clock), an external memory access malfunction occurs.
We have a problem when setting ebi bus clk 50mhz, 66mhz and it works normally when setting to 37.5mhz. Please refer to the picture.
Please check this problem
Thanks.
Woo
The problem has already been identified in the MPC5777C-516DS (EVB), and we received an answer from NXP distributor that we believe it is the problem of the EVB board itself.
The SRAM used now is CY7C1441KV33-133AXM, and the same issue is confirmed.
Woo
davidtosenovjan
For your reference or possible other readers of this thread - here there is a solution:
https://community.nxp.com/t5/MPC5xxx/Inquiries-about-MPC5777-EBI-bus-settings/m-p/1593529/highlight/...
Woo
I've checked the related content. Thanks for your help.
davidtosenovjan
So now you are using your own board?
There are newer revison of MPC5777C-516DS using different memory than before, but also different you have mentioned.
davidtosenovjan
davidtosenovjan
This is a known issue to me as I have observed the same behavior on my side.
Are you using our MPC5777C-516DS daughter card and the memory used on this board? Could you confirm?
