Does not work the ability to write registers in debug mode
Search instead for
olegivanus
Hi!
Why in debug mode does not work the ability to write registers? When I press "WRITE" on the panel "Registers" (LIN0CR1, and other)? I use u-multilink, CW10.5, MPC5643L?
Tags (3)
lukaszadrapa
are you sure that the peripheral is enabled in Mode Entry module? If not, it is not possible to write its registers...
Lukas
