Difference between mini-module and daughtercard
592 次查看
salmanc
I have a question. What is the difference between mini-module and daughter card? I was looking into https://www.nxp.com/part/XPC564AKIT176S#/ and https://www.nxp.com/part/MPC564AKIT176#/ development kits.
Their mother board is the same but one of them is with mini-module, the other is with daughter card.
Which abilities differ in these 2 kits? What is the difference?
Thanks in advance..
583 次查看
petervlna
For basic development I recommend XPC board.
But if you need in field trimming then you should pick up MPC one with vertical connector:
https://www.nxp.com/design/development-boards/automotive-development-platforms/mpc56xx-mcu-platforms...
Peter
580 次查看
salmanc
So what is the main difference between XPC564AADPT176S daughter card and MPC564AADPT176 mini-module? Which abilities differ from one to one?
Is the replacable MCU only difference? Is there any other difference?
574 次查看
petervlna
Both can be used with Mother board.
But MPC one is equipped with vertical connector for calibration purposes.
Peter
