DCU3 Setup instructions for PXD20 / MPC5645S
peteradamcik
Hi Guys, I'm setting up the DCU3 graphics display and almost ready to start setting up the registers in Assembler.
Before I start, is there a seperate .PDF to explain step by step to setup the DCU3 or any other info to help me set it up and run.
I already have the PXD20 reference manual which shows me the registers for the DCU3 but not actually to setup a 640x480@60Hz  display.
Any help would be very much appreciated.
Thanks guys, hope to hear from you soon.
Pete.
davidtosenovjan
Hi, please create new case (according procedure below) with reference to this thread.
https://www.nxp.com/video/tutorial-for-nxp-support-case-portal:NCP-VIDEO
I can send you some example codes and presentation slides. Thanks for understanding
peteradamcik
Hi David, I just tried to get a ticket for support and I received this error:
An unhandled fault has occurred in this flow
An unhandled fault has occurred while processing the flow. Please contact your system administrator for more information.
I guess the ticket page is down.
Pete
peteradamcik
Hi David, thank you for the link. Oh, YES please send me some code and presentation slides.
Much appreciated David
Pete
