Cannot erase / or write to the FLASH Memory on the MPC5748G
2,084件の閲覧回数
chfakhtchfakht
I was trying to erase all the flash memory but it gives me the following error:
FLASH algorithm did not execute completely
And if i try to flash my application it gives me:
bus error generated by CPU
Is there something that i can do ? thanks
3 返答(返信)
1,478件の閲覧回数
lukaszadrapa
that's too brief description. I'm not sure what's wrong. Could you try attached script file? Just rewrite the end of script and select the elf file you have.
Lukas
1,478件の閲覧回数
chfakhtchfakht
I have tried your script but it gave me emulation debug port failed !
1,478件の閲覧回数
lukaszadrapa
Could you send me your script file and binary file which you want to program to flash? I can try to reproduce and fix the problem here on my board...
Lukas
