Hi,I was trying to erase all the flash memory but it gives me the following error:
FLASH algorithm did not execute completely
And if i try to flash my application it gives me:
bus error generated by CPU
Is there something that i can do ? thanks
that's too brief description. I'm not sure what's wrong. Could you try attached script file? Just rewrite the end of script and select the elf file you have.
Lukas
I have tried your script but it gave me emulation debug port failed !
Could you send me your script file and binary file which you want to program to flash? I can try to reproduce and fix the problem here on my board...
