Can anyone tell me where to download a BSDL file for MPC5746R LFBGA252 ?
jimfalconer
I need a BSDL file for a MPC5746R LFBGA252 device
jimfalconer
Hi Lukas,
I have tried this file, without success.
First I had to edit the file because 2 pins were incorrectly numbered (TCK and GPIO_16 swapped) and I added the power pins as linkage bits.
I can now use it for boundary scan testing but it still fails.
It looks to me that the instruction register length does not match the device.
Are you sure this is the correct file for the MPC5746R ?
lukaszadrapa
Hi Jim,
the team will provide new version of the BSDL file, I will share it soon. Thanks for patience.
Lukas
lukaszadrapa
Hi Jim,
I just got the BSDL file. See please attachment. I hope it will work now.
Lukas
fang88
Hello there,
I wonder how to develop my own BSDL files? Do there exist some kind of tutorials for that?
Thank you.
fang88
Hello there,
Thank you.
lukaszadrapa
Hi Jim,
let me check this with responsible team if they are aware of this and if they have a solution. Please notice that it may take some time, so thank you for your patience.
Lukas
lukaszadrapa
Hi Jim,
see please attached file.
Lukas
jimfalconer
Thanks, I will give it a try.
Regards, Jim.
