Can you please suggest CAN transceiver with following specifications
1. Compliant with the ISO11898-1 (CAN 2.0B) protocol 2. Speed Minimum 1Mbps
3. With high Bus fault voltage protection 4. With silent, sleep and standby modes 5. IEC ESD Protection of Bus Terminals 6. Undervoltage Protection on Supply Terminals 7. Driver Dominant Time Out 8. Thermal Shutdown Protection
9. With Medical grade
10. Fault feedback to Microcontroller 11. With Local wake up input
