Hello NXP professionals,
I have a question about the Bits sequence of MPC5777C MCU on datasheet. When I looked at the datasheet, bits have been written in reverse compared to other MCU's datasheets.
Could you inform me whether I should shift bits by considering this layout or I should pay regard to a normal 32 bits layout while using bitwise operators (and, or).
Good works:))
Solved! Go to Solution.
you do not need to reverse the bits. MSB is bit 0, LSB is bit 31. You can see the same order of bits in the manual and in the memory map.
Lukas
Lukas
