I need to use internal Flash area internal_flash:0x10_0000.
But I met under message.
When I use internal_flash area under 0x10_0000. It's good and no problem to make binary.
Description Resource Path Location Type
Can't write binary file 'FLCC_TPS.bin' because gap between bin file offset for segments .bss and .__bam_bootarea wasn't updated correctly (too much). FLCC_TPS C/C++ Problem
I checked your question, but unfortunately, I do not understand it well. Could you please clarify your question and share your linker file and map file of your project?
Martin
This problem is resolved my myself.
The problem was caused by the incompatible ROM address of the CW and the .text section of ".lcf".
Henk
