About the S32DS installation DIAB software compilation error
Search instead for
lubo_NEW
According to the documentation to NXP has installed the DIAB compiler plug-in, after the installation to create a simple file but always prompt error
The following
"../Sources/main.c", fatal error (etoa:1635): License error: Unknown LMAPI error
mikedoidge
Hello @lubo_NEW,
Are you able to invoke the Diab compiler from the command line? Have you confirmed your license for Diab is valid?
Mike
lubo_NEW
The DIAB compiler license is not enabled
