About MPC5646C CAN demo
2,050件の閲覧回数
xinweichang
Hi, I am using MPC5646C CAN module and have encountered some problem. As the chip is uses FlexCAN module, I copied the CAN demo from 5744p, as 5744p also has a FlexCAN module. However, I found it hard to get it work. Is there a CAN demo for MPC5646C, or which demo is similar to it? Thank you!
2 返答(返信)
1,921件の閲覧回数
lukaszadrapa
attached you will find simple test for CAN.
Lukas
1,921件の閲覧回数
xinweichang
Thank you very much, it really helps me a lot.
