About MPC5646C CAN demo
xinweichang
Hi, I am using MPC5646C CAN module and have encountered some problem. As the chip is uses FlexCAN module, I copied the CAN demo from 5744p, as 5744p also has a FlexCAN module. However, I found it hard to get it work. Is there a CAN demo for MPC5646C, or which demo is similar to it? Thank you!
lukaszadrapa
attached you will find simple test for CAN.
Lukas
xinweichang
Thank you very much, it really helps me a lot.
