5777c eQADC A and B
5777c eQADC A and B
rosebank
I'm using 5777C with S32DS PA
I measure 16 channels from eQADC B(sw triggered cont scan) and 2 channels from eQADC A(hw triggered cont scan).
eQADC A, and eQADC B is working well if I use the eQADC separately, but one of them is not working when I use both eQADC A and B.
Last initialized eQADC is working well, but first one is not.
Anyone has an idea for solving this problem??
davidtosenovjan
Could you provide example code showing described behavior? Thanks
rosebank
Thank you for your help.
I found there is a bug in the eqadc_driver.c in SDK.
Also, another article regarding this issue has already been posted.
Please read the post below:
https://community.nxp.com/t5/S32-SDK/Simultaneous-usage-of-both-EQADC-modules-in-MPC5777C-using-DMA/...
davidtosenovjan
Thanks for information. It is good to know, I will report it to the SDK team.
