5748G static power consumption problem
395 次查看
jacst
We are on the 5748G DEMO board, do not perform any operation after power-on, and directly enter the standby mode. The actual measurement found that the power consumption is about 1.5mA. It is quite different from the following data. May I ask what could be the cause of this? Can this chip indeed achieve the following data? ?
384 次查看
lukaszadrapa
which board do you have exactly and where do you measure the current? Are you sure it is a current supplying only the MCU?
Lukas
