Example MPC5777C-SDADC_eTPU_triggered GHS714
* Detailed Description:
* Example configures Sigma_Delta ADC and periodically converts ANA0_SDA0 input
* (EVB's potentiometer can be connected i.e. J53-1 --> PO15) and displays
* results in the terminal window (USBtoUART bridge J21). Terminal settings is
* 19200-8-no parity-1 stop bit-no flow control on eSCI_A.
* Example uses external ADC triggering from eTPU channels, that are for purpose
* of this example configured for eTPU GPIO function for all eTPU channels that
* can trigger start of SDADC conversion.
* Test HW:         MPC5777C-512DS Rev.A + MPC57xx MOTHER BOARD Rev.C
* MCU:             PPC5777CMM03 2N45H CTZZS1521A
* Fsys:            PLL1 = core_clk = 264MHz, PLL0 = 192MHz
* Debugger:        Lauterbach Trace32
* Target:          internal_FLASH
* Terminal:        19200-8-no parity-1 stop bit-no flow control on eSCI_A
*                  eSCI_A is USBtoUART bridge (connector J21)
* EVB connection:  For ADC: J53-1 (EVB pot's wiper) --> PO15 (header P22)
Comments
Can you describe a little bit about its use? Hardware ,motor etc..
%3CLINGO-SUB%20id%3D%22lingo-sub-1101495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5777C-SDADC_eTPU_triggered%20GHS714%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Example%20configures%20Sigma_Delta%20ADC%20and%20periodically%20converts%20ANA0_SDA0%20input%3CBR%20%2F%3E*%20(EVB's%20potentiometer%20can%20be%20connected%20i.e.%20J53-1%20--%26gt%3B%20PO15)%20and%20displays%3CBR%20%2F%3E*%20results%20in%20the%20terminal%20window%20(USBtoUART%20bridge%20J21).%20Terminal%20settings%20is%20%3CBR%20%2F%3E*%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A.%3CBR%20%2F%3E*%20Example%20uses%20external%20ADC%20triggering%20from%20eTPU%20channels%2C%20that%20are%20for%20purpose%3CBR%20%2F%3E*%20of%20this%20example%20configured%20for%20eTPU%20GPIO%20function%20for%20all%20eTPU%20channels%20that%3CBR%20%2F%3E*%20can%20trigger%20start%20of%20SDADC%20conversion.%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5777C-512DS%20Rev.A%20%2B%20MPC57xx%20MOTHER%20BOARD%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5777CMM03%202N45H%20CTZZS1521A%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PLL1%20%3D%20core_clk%20%3D%20264MHz%2C%20PLL0%20%3D%20192MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%20%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20eSCI_A%20is%20USBtoUART%20bridge%20(connector%20J21)%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20For%20ADC%3A%20J53-1%20(EVB%20pot's%20wiper)%20--%26gt%3B%20PO15%20(header%20P22)%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1101495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Example%20configures%20Sigma_Delta%20ADC%20and%20periodically%20converts%20ANA0_SDA0%20input%3CBR%20%2F%3E*%20(EVB's%20potentiometer%20can%20be%20connected%20i.e.%20J53-1%20--%26gt%3B%20PO15)%20and%20displays%3CBR%20%2F%3E*%20results%20in%20the%20terminal%20window%20(USBtoUART%20bridge%20J21).%20Terminal%20settings%20is%20%3CBR%20%2F%3E*%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A.%3CBR%20%2F%3E*%20Example%20uses%20external%20ADC%20triggering%20from%20eTPU%20channels%2C%20that%20are%20for%20purpose%3CBR%20%2F%3E*%20of%20this%20example%20configured%20for%20eTPU%20GPIO%20function%20for%20all%20eTPU%20channels%20that%3CBR%20%2F%3E*%20can%20trigger%20start%20of%20SDADC%20conversion.%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5777C-512DS%20Rev.A%20%2B%20MPC57xx%20MOTHER%20BOARD%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5777CMM03%202N45H%20CTZZS1521A%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PLL1%20%3D%20core_clk%20%3D%20264MHz%2C%20PLL0%20%3D%20192MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%20%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20eSCI_A%20is%20USBtoUART%20bridge%20(connector%20J21)%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20For%20ADC%3A%20J53-1%20(EVB%20pot's%20wiper)%20--%26gt%3B%20PO15%20(header%20P22)%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5777C-SDADC_eTPU_triggered%20GHS714%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20you%20describe%20a%20little%20bit%20about%20its%20use%3F%20Hardware%20%2Cmotor%20etc..%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-22-2017 04:37 AM
Updated by:
