Example MPC5777C 3N45H MCAN-FD simpleTX-RX ISR GHS616
* Detailed Description:
* Configures the MCANs to transmit and receive a CAN FD message with or without
* bit rate switching for data phase. This is defined by BRS macro.
* Baudrate during arbitration phase is set to 500kbps, during data phase 1Mpbs
* because of PHY used on the EVB.
* In this config, MCAN_0 transmits a message. MCAN_1 receives the message.
* MCAN_0 sends message each 1sec. This interval is generated by PIT.
* Single TX buffer is used to send n bytes. The message ID is changed for each
* transmission. Two standard and 2 extended IDs are sent.
* MCAN_1 is configured to receive a message, ISR is used to read new message.
* There are 2 standard and 2 extended ID filter tables defined. Classic filter
* configuration is set, means filter ID & mask.
* Messages with matched standard ID are received into RXFIFO_0, messages with matched
* extended ID then stored in RXFIFO_1.
* EVB connection:
* J37 and J38 to position 2-3 to connect MCAN1 TX/RX to transceiver
* CAN0-CANH on P15-1 to CAN1-CANH on P14-1
* CAN0-CANL on P15-2 to CAN1-CANL on P14-2
* Test HW: MPC5777C-512DS Rev.D + MPC57xx MOTHER BOARD Rev.C
* MCU: SPC5777CCMM03 3N45H
* Fsys: PLL1 = core_clk = 264MHz, PLL0 = 192MHz
* Debugger: Lauterbach Trace32
* Target: internal_FLASH
* Terminal: 19200-8-no parity-1 stop bit-no flow control on eSCI_A
* use USB connector (J21) on minimodule
* EVB connection: ETPUA30 (PortP P23-15) --> USER_LED_1 (P7-1)
* ETPUA31 (PortP P23-14) --> USER_LED_2 (P7-2)
标签 (1)
附件
%3CLINGO-SUB%20id%3D%22lingo-sub-1107779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5777C%203N45H%20MCAN-FD%20simpleTX-RX%20ISR%20GHS616%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E%20*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20%E9%85%8D%E7%BD%AE%20MCAN%20%E5%8F%91%E9%80%81%E5%92%8C%E6%8E%A5%E6%94%B6%E5%B8%A6%E6%9C%89%E6%88%96%E4%B8%8D%E5%B8%A6%E6%9C%89%20CAN%20FD%20%E6%B6%88%E6%81%AF%3CBR%20%2F%3E*%20%E6%95%B0%E6%8D%AE%E9%98%B6%E6%AE%B5%E7%9A%84%E6%AF%94%E7%89%B9%E7%8E%87%E5%88%87%E6%8D%A2%E3%80%82%E8%BF%99%E6%98%AF%E7%94%B1%20BRS%20%E5%AE%8F%E5%AE%9A%E4%B9%89%E7%9A%84%E3%80%82%3CBR%20%2F%3E*%20%E4%BB%B2%E8%A3%81%E9%98%B6%E6%AE%B5%E7%9A%84%E6%B3%A2%E7%89%B9%E7%8E%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%20500kbps%EF%BC%8C%E6%95%B0%E6%8D%AE%E9%98%B6%E6%AE%B5%E7%9A%84%E6%B3%A2%E7%89%B9%E7%8E%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%201Mpbs%3CBR%20%2F%3E%20*%20%E5%9B%A0%E4%B8%BA%20EVB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E4%BA%86%20PHY%E3%80%82%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20%E5%9C%A8%E6%AD%A4%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8CMCAN_0%20%E4%BC%A0%E8%BE%93%E4%B8%80%E6%9D%A1%E6%B6%88%E6%81%AF%E3%80%82MCAN_1%E6%8E%A5%E6%94%B6%E6%B6%88%E6%81%AF%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20MCAN_0%20%E6%AF%8F%201%20%E7%A7%92%E5%8F%91%E9%80%81%E4%B8%80%E6%AC%A1%E6%B6%88%E6%81%AF%E3%80%82%E8%AF%A5%E9%97%B4%E9%9A%94%E7%94%B1%20PIT%20%E7%94%9F%E6%88%90%E3%80%82%3CBR%20%2F%3E%20*%20%E5%8D%95%E4%B8%AA%20TX%20%E7%BC%93%E5%86%B2%E5%8C%BA%E7%94%A8%E4%BA%8E%E5%8F%91%E9%80%81%20n%20%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%E6%AF%8F%E6%AC%A1%3CBR%20%2F%3E*%20%E4%BC%A0%E6%92%AD%E3%80%82%E5%8F%91%E9%80%81%E4%B8%A4%E4%B8%AA%E6%A0%87%E5%87%86%20ID%20%E5%92%8C%202%20%E4%B8%AA%E6%89%A9%E5%B1%95%20ID%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20MCAN_1%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%8E%A5%E6%94%B6%E6%B6%88%E6%81%AF%EF%BC%8CISR%20%E7%94%A8%E4%BA%8E%E8%AF%BB%E5%8F%96%E6%96%B0%E6%B6%88%E6%81%AF%E3%80%82%3CBR%20%2F%3E*%20%E5%AE%9A%E4%B9%89%E4%BA%862%E4%B8%AA%E6%A0%87%E5%87%86%E5%92%8C2%E4%B8%AA%E6%89%A9%E5%B1%95ID%E8%BF%87%E6%BB%A4%E8%A1%A8%E3%80%82%E7%BB%8F%E5%85%B8%E8%BF%87%E6%BB%A4%E5%99%A8%3CBR%20%2F%3E*%20%E9%85%8D%E7%BD%AE%E5%B7%B2%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%A1%A8%E7%A4%BA%E8%BF%87%E6%BB%A4%E5%99%A8%20ID%20%E5%92%8C%E6%8E%A9%E7%A0%81%E3%80%82%3CBR%20%2F%3E*%20%E5%85%B7%E6%9C%89%E5%8C%B9%E9%85%8D%E6%A0%87%E5%87%86%20ID%20%E7%9A%84%E6%B6%88%E6%81%AF%E8%A2%AB%E6%8E%A5%E6%94%B6%E5%88%B0%20RXFIFO_0%20%E4%B8%AD%EF%BC%8C%E5%85%B7%E6%9C%89%E5%8C%B9%E9%85%8D%3CBR%20%2F%3E*%20%E6%89%A9%E5%B1%95ID%E7%84%B6%E5%90%8E%E5%AD%98%E5%82%A8%E5%9C%A8RXFIFO_1%E4%B8%AD%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20J37%20%E5%92%8C%20J38%20%E8%87%B3%E4%BD%8D%E7%BD%AE%202-3%EF%BC%8C%E5%B0%86%20MCAN1%20TX%2FRX%20%E8%BF%9E%E6%8E%A5%E8%87%B3%E6%94%B6%E5%8F%91%E5%99%A8%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20P15-1%20%E4%B8%8A%E7%9A%84%20CAN0-CANH%20%E8%87%B3%20P14-1%20%E4%B8%8A%E7%9A%84%20CAN1-CANH%3CBR%20%2F%3E%20*%20P15-2%20%E4%B8%8A%E7%9A%84%20CAN0-CANL%20%E8%87%B3%20P14-2%20%E4%B8%8A%E7%9A%84%20CAN1-CANL%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20----------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC5777C-512DS%20Rev.D%20%2B%20MPC57xx%20%E4%B8%BB%E6%9D%BF%20Rev.C%3CBR%20%2F%3E%20*%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%3A%20SPC5777CCMM03%203N45H%3CBR%20%2F%3E%20*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9APLL1%20%3D%20core_clk%20%3D%20264MHz%EF%BC%8CPLL0%20%3D%20192MHz%3CBR%20%2F%3E%20*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9ALauterbach%20Trace32%3CBR%20%2F%3E%20*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3CBR%20%2F%3E%20*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3CBR%20%2F%3E*%20%E4%BD%BF%E7%94%A8%E5%BE%AE%E5%9E%8B%E6%A8%A1%E5%9D%97%E4%B8%8A%E7%9A%84%20USB%20%E8%BF%9E%E6%8E%A5%E5%99%A8%20(J21)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9AETPUA30%EF%BC%88PortP%20P23-15%EF%BC%89--%26gt%3B%20USER_LED_1%EF%BC%88P7-1%EF%BC%89%3CBR%20%2F%3E%20*%20ETPUA31%20(%E7%AB%AF%E5%8F%A3%20P23-14)%20--%26gt%3B%20USER_LED_2%20(P7-2)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1107779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎11-07-2018 12:59 AM
更新人:
