Example MPC5775K-UART_with_Interrupts S32DS_1.0
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* setup clock for peripherals,
* LINFlex UART mode transmit and receive with interrupts
* Test HW:         MPC5775K-356DS, MPC57xx Motherboard
* MCU:             PPC5775KMMY3A 0N38M
* Terminal:        19200-8-no parity-1 stop bit-no flow control on LINFlexD_0
* Fsys:            PLL0 266MHz
*                    Z4 Core 133MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  J14.2 to P12.6 Connect LINFlexD_0 RXD to main RS232
*                  J13.2 to P12.7 Connect LINFlexD_0 TXD to main RS232
添付
コメント
I am looking for a UART driver with Interrupt for MPC5748G micro but you have shared for MPC5775K.
Please provide the required project
My requirement: Transmit and receive 9 bytes of hex values as shown below.
TxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19}
URGENT!!: Please provide an example code for the MPC5748G EVB board with Tx & Rx interrupt for my requirement.
This change will be used in our production program (FORD OEM).
Please provide the procedure to test your example code
Please review my Uart7_Rx_Isr code below:
void Uart7_Rx_Isr (void)
    unsigned char Channel = 7U;
    unsigned char Data;
    if (1 == LINFlexD_7.UARTSR.B.DRFRFE)
        Data = LINFlexD_7.BDRM.B.DATA4;
        LINFlexD_7.UARTSR.R &= UART_DRFRFE;      /* Clear data reception flag W1C */
       /*Save received data*/
       if (BufferTxdisplay_index < UART_7_TX_MAX_LENGTH)   //0 <12
           BufferTxdisplay[BufferTxdisplay_index] = Data;
           BufferTxdisplay_index++;
     if( (BufferTxdisplay_index >= 9) )
        BufferTxdisplay_index = 0;
I am attempting to read all 9 bytes using the above Rx ISR, but I am only receiving the first byte repeatedly, which is 0x11.
Expected Output:
TxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19};
RxBuffer[9] = {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19};
Actual Output:
RxBuffer[9] = {0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11};
Could you please suggest what the issue is in the RxISR routine?
Please provide the correct Uart7_Rx_Isr routine to read valid 9 bytes and Uart7_Tx_Isr and Transmit function as well.
Please provide the procedure to test your code
%3CLINGO-SUB%20id%3D%22lingo-sub-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8B%20MPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81PLL%E3%82%92%E6%9C%80%E5%A4%A7%E8%A8%B1%E5%AE%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20LINFlex%20UART%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BB%98%E3%81%8D%E3%81%A7%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5775K-356DS%E3%80%81MPC57xx%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3A%200N38M%3C%2FP%3E%3CP%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-LINFlexD_0%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%20Fsys%3APLL0%20266MHz%3C%2FP%3E%3CP%3E*%20Z4%E3%82%B3%E3%82%A2133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E%E2%80%BB%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3AJ14.2%E3%80%9CP12.6%20RXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20J13.2%E3%81%8B%E3%82%89P12.7TXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81PLL%E3%82%92%E6%9C%80%E5%A4%A7%E8%A8%B1%E5%AE%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20LINFlex%20UART%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BB%98%E3%81%8D%E3%81%A7%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5775K-356DS%E3%80%81MPC57xx%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3A%200N38M%3C%2FP%3E%3CP%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-LINFlexD_0%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%20Fsys%3APLL0%20266MHz%3C%2FP%3E%3CP%3E*%20Z4%E3%82%B3%E3%82%A2133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E%E2%80%BB%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3AJ14.2%E3%80%9CP12.6%20RXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20J13.2%E3%81%8B%E3%82%89P12.7TXD%20LINFlexD_0%E3%83%A1%E3%82%A4%E3%83%B3RS232%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E4%BE%8BMPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E4%BE%8BMPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%A7%81%E3%81%AEUart7_Rx_Isr%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CDIV%3Evoid%20Uart7_Rx_Isr%20(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eunsigned%20char%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%3D%207U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eunsigned%20char%20%E3%83%87%E3%83%BC%E3%82%BF%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20if%20(1%20%3D%3D%20LINFlexD_7.UARTSR.B.DRFRFE)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Data%20%3D%20LINFlexD_7.BDRM.B.DATA4%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ELINFlexD_7.UARTSR%E3%81%A7%E3%81%99%E3%80%82R%20%26amp%3B%3D%20UART_DRFRFE%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F*%20%E3%83%87%E3%83%BC%E3%82%BF%E5%8F%97%E4%BF%A1%E3%83%95%E3%83%A9%E3%82%B0%20W1C%20%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BF%9D%E5%AD%98*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif%20(BufferTxdisplay_index%20%26lt%3B%20UART_7_TX_MAX_LENGTH)%20%2F%2F0%20%26lt%3B12%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BBufferTxdisplay%5BBufferTxdisplay_index%5D%20%3D%20Data%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BBufferTxdisplay_index%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bif(%20(BufferTxdisplay_index%20%26gt%3B%3D%209)%20)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20BufferTxdisplay_index%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E4%B8%8A%E8%A8%98%E3%81%AE%20Rx%20ISR%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%209%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8D%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%20(%E3%81%93%E3%82%8C%E3%81%AF%200x11)%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8B%E5%87%BA%E5%8A%9B%3A%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ETxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EActual%20Output%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3ETxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%2C%200x11%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERxISR%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%AE%E5%95%8F%E9%A1%8C%E7%82%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%E3%81%AA9%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84Uart7_Rx_Isr%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%A8%E3%80%81Uart7_Tx_Isr%E3%81%8A%E3%82%88%E3%81%B3%E9%80%81%E4%BF%A1%E6%A9%9F%E8%83%BD%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E4%BE%8BMPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E4%BE%8BMPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A6%81%E4%BB%B6%3A%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%819%E3%83%90%E3%82%A4%E3%83%88%E3%81%AEhex%E5%80%A4%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ETxBuffer%5B9%5D%20%3D%20%7B0x11%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%2C%200x17%2C%200x18%2C%200x19%7D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EURGENT!!%3A%20%E7%A7%81%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%81Tx%20%E3%81%8A%E3%82%88%E3%81%B3%20Rx%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%90%AB%E3%82%80%20MPC5748G%20EVB%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%AE%E7%94%9F%E7%94%A3%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0(FORD%20OEM)%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1867956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E4%BE%8BMPC5775K-UART_with_Interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1867956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFMPC5748G%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%94%A8%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%82%99%E3%81%88%E3%81%9FUART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AFMPC5775K%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-12-2016 06:19 AM
更新者:
