Example MPC5748G-FlexCAN_with_interrupts S32DS_1.0
* Detailed Description:
* This example shows, how to initialize FlexCAN modules for simple transmission
* and reception using RX interrupt. Both modules are configured for 100kbit/s
* bit rate. CAN_0 module transmits message using MB0. CAN_1 module receives
* message using interrupt via MB0.
* Test HW:         MPC5748G-324DS, MPC574XG - Motherboard
* MCU:             PPC5748GMMN6A 1N81M
* Fsys:            PLL0 160MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  Connect jumpers J15 and J16 on motherboard
*                    Connect P14 H to P15 H
*                    Connect P14 L to P15 L
标签 (1)
附件
评论
Hi,I download your code,it can run,but i have some problems when debug it.
when i debug it ,it would go to dummy interruption function。like below picture,
then,i press the F5(step into),it will enter main() function.like below;
I'm confused, why it's not the first to go into main () function. Thank you .
YSl
which version of S32DS you use? If you recompiled this in S32DS v1.2 or R1.2017, it would not work correct, because there are some significant changes in compiler.
Martin
Do you have the example with DMA enabled on FlexCAN?
Xiaofeng
Hello martinkovar,
Do you have any updated version of this example to work with the SDK or new version of compiler?
If not, could you please tell me what should I do to get this example to work on R1.2017?
Thank you so much
if you want FlexCAN example based on SDK, this is directly included in S32 Design Studio.
If you want to use this one. you can simply create new project and manually migrate source codes or you can try to use following tutorial
https://community.nxp.com/docs/DOC-335361
Martin
Thank you,
It works
%3CLINGO-SUB%20id%3D%22lingo-sub-1102587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5748G-FlexCAN_with_interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E6%9C%AC%E4%BE%8B%E6%BC%94%E7%A4%BA%E5%A6%82%E4%BD%95%E5%88%9D%E5%A7%8B%E5%8C%96%20FlexCAN%20%E6%A8%A1%E5%9D%97%E4%BB%A5%E8%BF%9B%E8%A1%8C%E7%AE%80%E5%8D%95%E4%BC%A0%E8%BE%93%3C%2FP%3E%3CP%3E*%E5%B9%B6%E4%BD%BF%E7%94%A8%20RX%20%E4%B8%AD%E6%96%AD%E6%8E%A5%E6%94%B6%E3%80%82%E4%B8%A4%E4%B8%AA%E6%A8%A1%E5%9D%97%E5%9D%87%E9%85%8D%E7%BD%AE%E4%B8%BA%20100kbit%2Fs%3C%2FP%3E%3CP%3E*%20%E6%AF%94%E7%89%B9%E7%8E%87%E3%80%82CAN_0%E6%A8%A1%E5%9D%97%E4%BD%BF%E7%94%A8MB0%E4%BC%A0%E8%BE%93%E6%B6%88%E6%81%AF%E3%80%82CAN_1%E6%A8%A1%E5%9D%97%E6%8E%A5%E6%94%B6%3C%2FP%3E%3CP%3E*%20%E9%80%9A%E8%BF%87%20MB0%20%E4%BD%BF%E7%94%A8%E4%B8%AD%E6%96%AD%E7%9A%84%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC5748G-324DS%E3%80%81MPC574XG%20-%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3E*%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%3A%20PPC5748GMMN6A%201N81M%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9APLL0%20160MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%EF%BC%88%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%81%E5%8F%91%E5%B8%83%E6%A8%A1%E5%BC%8F%EF%BC%89%3C%2FP%3E%3CP%3E*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9A%E8%BF%9E%E6%8E%A5%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%E8%B7%B3%E7%BA%BF%20J15%20%E5%92%8C%20J16%3C%2FP%3E%3CP%3E*%20%E5%B0%86%20P14%20H%20%E8%BF%9E%E6%8E%A5%E8%87%B3%20P15%20H%3C%2FP%3E%3CP%3E*%20%E5%B0%86%20P14%20L%20%E8%BF%9E%E6%8E%A5%E8%87%B3%20P15%20L%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1102587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E6%9C%AC%E4%BE%8B%E6%BC%94%E7%A4%BA%E5%A6%82%E4%BD%95%E5%88%9D%E5%A7%8B%E5%8C%96%20FlexCAN%20%E6%A8%A1%E5%9D%97%E4%BB%A5%E8%BF%9B%E8%A1%8C%E7%AE%80%E5%8D%95%E4%BC%A0%E8%BE%93%3C%2FP%3E%3CP%3E*%E5%B9%B6%E4%BD%BF%E7%94%A8%20RX%20%E4%B8%AD%E6%96%AD%E6%8E%A5%E6%94%B6%E3%80%82%E4%B8%A4%E4%B8%AA%E6%A8%A1%E5%9D%97%E5%9D%87%E9%85%8D%E7%BD%AE%E4%B8%BA%20100kbit%2Fs%3C%2FP%3E%3CP%3E*%20%E6%AF%94%E7%89%B9%E7%8E%87%E3%80%82CAN_0%E6%A8%A1%E5%9D%97%E4%BD%BF%E7%94%A8MB0%E4%BC%A0%E8%BE%93%E6%B6%88%E6%81%AF%E3%80%82CAN_1%E6%A8%A1%E5%9D%97%E6%8E%A5%E6%94%B6%3C%2FP%3E%3CP%3E*%20%E9%80%9A%E8%BF%87%20MB0%20%E4%BD%BF%E7%94%A8%E4%B8%AD%E6%96%AD%E7%9A%84%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC5748G-324DS%E3%80%81MPC574XG%20-%20%E4%B8%BB%E6%9D%BF%3C%2FP%3E%3CP%3E*%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%3A%20PPC5748GMMN6A%201N81M%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9APLL0%20160MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%EF%BC%88%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%81%E5%8F%91%E5%B8%83%E6%A8%A1%E5%BC%8F%EF%BC%89%3C%2FP%3E%3CP%3E*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9A%E8%BF%9E%E6%8E%A5%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%E8%B7%B3%E7%BA%BF%20J15%20%E5%92%8C%20J16%3C%2FP%3E%3CP%3E*%20%E5%B0%86%20P14%20H%20%E8%BF%9E%E6%8E%A5%E8%87%B3%20P15%20H%3C%2FP%3E%3CP%3E*%20%E5%B0%86%20P14%20L%20%E8%BF%9E%E6%8E%A5%E8%87%B3%20P15%20L%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1102587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8BMPC5748G-FlexCAN_with_interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%9C%89%E7%94%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8BMPC5748G-FlexCAN_with_interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E8%A6%81%E5%9F%BA%E4%BA%8E%20SDK%20%E7%9A%84%20FlexCAN%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%BF%99%E7%9B%B4%E6%8E%A5%E5%8C%85%E5%90%AB%E5%9C%A8%20S32%20Design%20Studio%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%AE%80%E5%8D%95%E5%9C%B0%E5%88%9B%E5%BB%BA%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%B9%B6%E6%89%8B%E5%8A%A8%E8%BF%81%E7%A7%BB%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%88%96%E8%80%85%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E6%95%99%E7%A8%8B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335361%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335361%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EMartin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8BMPC5748G-FlexCAN_with_interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fmartinkovar%22%20target%3D%22_blank%22%3Emartinkovar%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E6%AD%A4%E7%A4%BA%E4%BE%8B%E7%9A%84%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%E5%8F%AF%E4%BB%A5%E4%B8%8E%20SDK%20%E6%88%96%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%E7%BC%96%E8%AF%91%E5%99%A8%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%E6%89%8D%E8%83%BD%E8%AE%A9%E8%BF%99%E4%B8%AA%E7%A4%BA%E4%BE%8B%E5%9C%A8%20R1.2017%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A4%AA%E6%84%9F%E8%B0%A2%E4%BA%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8BMPC5748G-FlexCAN_with_interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%9C%A8%20FlexCAN%20%E4%B8%8A%E5%90%AF%E7%94%A8%20DMA%20%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%B0%8F%E5%B3%B0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8BMPC5748G-FlexCAN_with_interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84S32DS%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%20S32DS%20v1.2%20%E6%88%96%20R1.2017%20%E4%B8%AD%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91%E5%AE%83%EF%BC%8C%E5%AE%83%E5%B0%86%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%BC%96%E8%AF%91%E5%99%A8%E4%B8%AD%E6%9C%89%E4%B8%80%E4%BA%9B%E9%87%8D%E5%A4%A7%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EMartin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8BMPC5748G-FlexCAN_with_interrupts%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E6%98%AF%E8%B0%83%E8%AF%95%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E8%B0%83%E8%AF%95%E5%AE%83%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E8%BF%9B%E5%85%A5%E8%99%9A%E6%8B%9F%E4%B8%AD%E6%96%AD%E5%87%BD%E6%95%B0%E3%80%82%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45242i2FA59154CF4EBA4C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211.png%22%20alt%3D%2211.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E6%8C%89%20F5%EF%BC%88%E5%8D%95%E6%AD%A5%E8%BF%9B%E5%85%A5%EF%BC%89%EF%BC%8C%E5%AE%83%E5%B0%86%E8%BF%9B%E5%85%A5%20main%EF%BC%88%EF%BC%89%E5%87%BD%E6%95%B0%E3%80%82%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45359i0FFCFD0272B36032%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222.png%22%20alt%3D%2222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BE%88%E5%9B%B0%E6%83%91%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E5%AE%83%E4%B8%8D%E6%98%AF%E7%AC%AC%E4%B8%80%E4%B8%AA%E8%BF%9B%E5%85%A5main%EF%BC%88%EF%BC%89%3CSPAN%3E%E5%87%BD%E6%95%B0%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E5%8F%B6%E9%85%B8%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-23-2016 06:28 AM
更新人:
