Example MPC5748G FlexCAN FD simple TX/RX GHS614
* Detailed Description:
* Configures the FlexCANs to transmit and receive a CAN FD message with or without
* bit rate switching for data phase.
* Baudrate during arbitration phase is set to 500kbps, during data phase 2Mpbs.
* In this config, CAN_0 transmits a message. CAN_1 receives the message.
* EVB connection:
* CAN0-CANH on P15-1 to CAN1-CANH on P14-1
* CAN0-CANL on P15-2 to CAN1-CANL on P14-2
* NOTE! Termination resistor (120Ohm) have to be placed on transceivers output
* Test HW:  X-MPC574xG-324DS + X-MPC574XG-MB
* Maskset:  1N81M
* Target :  FLASH
* Fsys:     160 MHz PLL
添付
コメント
HI!
Which CAN FD analyzer do you use?
I did not use CAN analyzer, only scope and debugger.
Petr
Hi.
I want use MB[1] receive CAN FD.
I only modify "void FlexCAN1_Init(void)" this section:
CAN_1.MB[1].CS.B.IDE = 0;
CAN_1.MB[1].ID.B.ID_STD = 0;
CAN_1.MB[1].CS.B.CODE = 4;
And modify "void ReceiveMsgFD(void)" this Section:
while (CAN_1.IFLAG1.B.BUF4TO1I != 1) {};  /* Wait for CAN 1 MB 1 flag */
but always stopped at  "while (CAN_1.IFLAG1.B.BUF4TO1I != 1) {};  "
Where i lost initialization CAN1 of MB[1] setting?
How can i do?
Jim Huang
did you really sent message with std ID = 0, so it can be received into MB1? Mask register RXIMR[1] was set 0x1FFFFFFF so the received ID must equal.
Also check the IFLAG1 register directly in the debugger if flag is set or not.
BR, Petr
I imported this project into my S32 Design Studio. Import method is File -> Import -> Project from Folder or Archive. But I can not build or debug this project anymore. Do you know why? I just started using this IDE, thank you!
Tianxiang
%3CLINGO-SUB%20id%3D%22lingo-sub-1127742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlexCAN%20FD%20simple%20TX%2FRX%20GHS614%20MPC5748G%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20FlexCANs%E3%81%8CCAN%20FD%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%82%20%3CBR%20%2F%3E*%20%E3%82%A2%E3%83%BC%E3%83%93%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF500kbps%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AF2Mpbs%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81CAN_0%20%E3%81%8C%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CAN_1%20%E3%81%AF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20P15-1%E3%81%AECAN0-CANH%E3%81%8B%E3%82%89P14-1%E3%81%AECAN1-CANH%3CBR%20%2F%3E*%20P15-2%20%E3%81%AE%20CAN0-CANL%20%E3%81%8B%E3%82%89%20P14-2%20%E3%81%AE%20CAN1-CANL%3CBR%20%2F%3E*%3CBR%20%2F%3E*%E6%89%8B%E8%A8%98%EF%BC%81%E7%B5%82%E7%AB%AF%E6%8A%B5%E6%8A%97(120%CE%A9)%E3%81%AF%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E5%87%BA%E5%8A%9B%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AX-MPC574xG-324DS%20%2B%20X-MPC574XG-MB%3CBR%20%2F%3E*%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%BB%E3%83%83%E3%83%88%3A1N81M%3CBR%20%2F%3E%E2%80%BB%E5%AF%BE%E8%B1%A1%3AFLASH%3CBR%20%2F%3E*%20Fsys%3A160%20MHz%20PLL%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1127742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎12-15-2016 06:06 AM
更新者:
